1 members (moparguy), 39 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#49255 08/19/2005 3:43 AM
I forget. On the 235 six where if any gaskets are placed between bakelite heat insulator, carb and manifold. Is it none, one between carb and bakelite or one each between carb bakelite and bakelite manifold?
My rule of life: You can have anything you want; you just can't have everything you want.
#49256 08/19/2005 12:29 PM
evergreenw,
No gasket between the insulation plate and intake manifold (but I think a gasket there would cause no problems).
The insulation plate should have the side with the indentations (for vacuum?) on the top.
The gasket goes between the carburetor and insulation plate (with the cut-outs in the gasket lining up with the indentation in the insulator plate and lining also up with the (vacuum?) hole in the base of the carburetor.
Tim
#49257 08/19/2005 3:55 PM
I've got one on both sides of the insulator. It works fine. If you are only going to use one do as Tim says and put it under the carb. Just make sure you have the cut-out for the vacuum holes all lined up.
George
#49258 08/19/2005 6:14 PM
wink
I think you definately want to use two. If not, I'm afraid you might have a slight vacuum leak and you also might have a fuel leak there.
Joe
