10 members (DadsFirstPickup, TUTS 59, JW51, GRNHydra, Ponchogl, GradyB, Leo, Jon G, walterhvogel, 1 invisible),
50
0
Mod | | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49255 08/19/2005 3:43 AM | Joined: Jun 2004 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 37 | I forget. On the 235 six where if any gaskets are placed between bakelite heat insulator, carb and manifold. Is it none, one between carb and bakelite or one each between carb bakelite and bakelite manifold?
My rule of life: You can have anything you want; you just can't have everything you want.
#49256 08/19/2005 12:29 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | evergreenw,
No gasket between the insulation plate and intake manifold (but I think a gasket there would cause no problems).
The insulation plate should have the side with the indentations (for vacuum?) on the top.
The gasket goes between the carburetor and insulation plate (with the cut-outs in the gasket lining up with the indentation in the insulator plate and lining also up with the (vacuum?) hole in the base of the carburetor.
Tim | | |
#49257 08/19/2005 3:55 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I've got one on both sides of the insulator. It works fine. If you are only going to use one do as Tim says and put it under the carb. Just make sure you have the cut-out for the vacuum holes all lined up. George | | |
#49258 08/19/2005 6:14 PM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I think you definately want to use two. If not, I'm afraid you might have a slight vacuum leak and you also might have a fuel leak there. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
