| | | Forums66 Topics128,264 Posts1,058,355 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Most people here say that you don't have to use it unless you are using the motor under extreme conditions. I use lead substitute just to be safe. You can get it at Walmart and probably just about anywhere else that sells auto things. | | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | Lead substitute is relatively cheap compared to the consequences. 20 years ago we still had a lot of people farming with pre 1975 equipment. Those who did not use leaded gas or a lead substitute had lots of valve trouble. I'm not exactly sure where you draw the line between extreme conditions and casual driving. | | | | | Joined: Dec 2007 Posts: 1,403 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 1,403 | Yep, doesn't that old saying go something like this? "Better to be safe than sorry." | | | | | Joined: Aug 2005 Posts: 6,379 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,379 | I've run "leaded" engines for years on both my pre unleaded Harley and my '38. I've never had a problem. If you want to spend the money it's up to you but unless you're pulling heavy loads all day it's not necessary.
| | | | | Joined: Jan 2009 Posts: 5 New Guy | | New Guy Joined: Jan 2009 Posts: 5 | Short Answer: I wouldn't worry about it. I'd just stick with premium and avoid gasolines with more than single digit quantites of ethanol in it.
Long answer (if you hated chemistry, skip):
Leaded gasoline contains tetraethyl lead. It's an "octane booster" that makes it easier to achieve higher compression without premature ignition (more power!). The octane rating of gasoline (87, 89, 93) is the amount of compression the gasoline can take before "knocking" when compared to isoctane gase (100). You can actually have octane ratings above 100.
Tetraethyl lead was the first widespread octane booster. It was gradually replaced by better, more environmentally-friendly alternatives (MTBE and ethanol). MTBE is falling out of favor due to groundwater contamination and is generally being replaced by ethanol in 1-5% blends. Ethanol can provide for more complete combustions, but it raises the vapor point during warm months (leading to smog) and ethanol is more corrosive to certain types of seals.
In general, just go with the highest octane gas you can find and avoid ethanol blends and you'll be fine. Unleaded gasoline will cause SLIGHTLY more erosion around the valve seats, but it will take tens of thousands of miles to show any effect.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No need for using Premuim gas, unless you've got over 9.5:1 compression. Waste of $$$ to use it in a vehicle that doesn't call for it. If you don't push it hard, regular unleaded will do fine. I've seen old pre-unleaded vehicle run on unleaded for years with no problems, and ehtanol doesn't seem to make any difference either.
Bill Burmeister | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | Actually, tetra-ethyl lead also provides a lubricating action for the valve seats. Octane rating makes no difference until you get low enough to get into 'knock' country. Also remember, an engine can be knocking long before you can hear it.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
