4 members (Shade Baby, Hotrod Lincoln, Otto Skorzeny, 1 invisible), 94 guests, and 2 robots.
Topics128,026
Posts1,055,410
Members48,422
#491516 01/09/2009 6:27 PM
3/4 ton w/ about a half a foot of leaf springs. I am trying to put on new shocks and they are about 3 inches to short to get to the bottom studs. their fully extended. hate to try to knock out the shackle rods to get the frame and axle closer. the problem here is I cant get the axle and frame close enough to each other to get the bottom of the shock absorber to its bottom bolt.
56 stepside 3/4 ton longbed
56 stepside #491535 01/09/2009 7:33 PM
Sounds like you need a longer shock. Shocks are mostly designed to dampen movement, not limit travel.
MNSmith #492073 01/11/2009 3:44 PM
Sounds like you have the wrong shocks
if you still have the old shocks measure them and then go through the monroe book bye size ,unless there is a number stamped on the bottom of them the can cross over . the newer catalog applications leave a lot to be desired if any . this is what i had to do on my ole man's 1940 (nee action )newer chevy lower shock Mount's complete low buck re do .
old dog #492164 01/11/2009 9:01 PM
Sounds like they might have given you a 3100 shock. The rear shocks for the 3200 and 3600 are longer than the 3100 for '55/'56 ('57-'59 the 3100 uses the same shock as the 32/3600).
The Monroe number for the rear is 37188, 83634 in a Sears number (same shock, different part number).
Bill Burmeister
LONGBOX55 #492178 01/11/2009 10:00 PM
bill, your the man. i am always amazed at your knowlege.
keep helping us guys out, we love it.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
RATRODKING #492231 01/12/2009 12:33 AM
Hey rat, you keep talkin like that and bill is gonna get a "fathead" smile
