7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49210 08/18/2005 3:46 PM | Joined: Sep 2003 Posts: 6 Junior Member | | Junior Member Joined: Sep 2003 Posts: 6 | i've got a '58 apache with a 235 that seems to lose fuel pressure after about 3 miles of running. i've checked all the obvious stuff. pump is delivering pressure, filter is good, lines are not too close to the engine to cause vapor lock. had the carb rebuilt a year ago. after i got stumped i took it to my local shop and they couldn't find anything. and i trust these guys. i don't think the tank is too rusty, because the fuel is running clean and the filter isn't catching too much gunk. anybody got any ideas?
thanks
david krause
chicago | | |
#49211 08/18/2005 6:11 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey welcome to the "real shop" David! just what does 'seems to lose fuel pressure' mean? if it runs the carb bowl empty, then next question is: does this happen on level ground and is the tank full, or nearly so? "pump is delivering pressure" says you haven't really checked the fuel pump! if it appears to run outta gas when you hit a slight up hill, or when you accelerate harder, and particularly when the tank is quite low, you have a worn actuator arm on the fuel pump or the rod that pushes it is worn excessively - pull it and take a look at the amount of wear - if you think the pump is good but there's excessive wear on that arm you can lay a bit of weld on it or on the pump end of the push rod - otherwise replace the pump and I'd bet yer problem will be gone - report back! Bill | | |
#49212 08/18/2005 10:21 PM | Joined: Sep 2003 Posts: 6 Junior Member | | Junior Member Joined: Sep 2003 Posts: 6 | thanks for the advice. i'll give it a shot. for $40 it's worth it to go ahead and replace the pump. i'll let you know what happens.
dk | | |
#49213 08/19/2005 1:16 AM | Joined: Jul 2005 Posts: 226 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2005 Posts: 226 | carb float stickin..??? or needle and seat...??? maybe some water or junk floatin or sinkin around in the float bowl too..???
What it will say on my Tombstone: "Boy, that guy sure owed alotta people Money"
#49214 08/19/2005 1:53 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | You can do a simple test to check the pump. No sense replacing it if it's good.
Make absolutely certain it's not a spark problem then check the in-tank filter.
delete my account and pictures
#49215 08/19/2005 1:55 AM | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | oh, and you say, "filter is good" . How do you know? Do you have an inline fuel filter? They can look good but be clogged. If you don't have an inline fuel filter, you'll need one. I'm betting that it's crud in the tank though. Let us know.
#49216 08/19/2005 2:32 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | naaah, it's the worn arm on the pump - been there, done that - looks like it pumps fine as long as the tanks not real low and there's no real load on the engine, so when ya check the pump you're fooled - gotta take it out and look at the wear we'll see what the response is to a new pump - if it's not fixed at least there's a spare pump on hand!  but it could be the rod is worn too Bill | | |
#49217 08/30/2005 8:49 PM | Joined: Sep 2003 Posts: 6 Junior Member | | Junior Member Joined: Sep 2003 Posts: 6 | put in a new pump, for 29.00 it was worth the peace of mind. it definitely increased the pressure. but i still have the same problem. runs well for 4-5 miles, then acts as if it's running out of fuel. new fuel filter, carb was rebuilt last year, so i feel good about the fuel system, will check the fuel tank strainer next. otherwise i'm stumped. | | |
#49218 08/31/2005 3:19 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Check to see if the filler cap is vented. | | |
#49219 08/31/2005 5:23 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Very good point Cletis! If that gas tank cap isn't vented, it's like trying to pour gas out of a five gallon can with out an air hole. It comes out, but slow. With a vented cap, it will come out like out of the can with an air hole. And that's just about how far it will run with out air. With a full tank, it wouldn't run near that far because there is no room for air in the tank. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
#49220 08/31/2005 12:53 PM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | My wife actually imploaded two gas tanks on her Chevy Corsica before the service department at the dealer finally replaced the gas cap that was not venting. She had the same symptoms you discribe where it felt like she was running out of gas, so she would stop and put in more gas and was only able to put in a very little, since the tank was full. Then the car would drive good for awhile and then it would start all over again. Next time you lose power try removing the gas cap and see if you now get your power back.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#49221 08/31/2005 3:05 PM | Joined: Sep 2003 Posts: 6 Junior Member | | Junior Member Joined: Sep 2003 Posts: 6 | i'll try that today. thanks for the info. | | |
#49222 09/13/2005 8:07 PM | Joined: Sep 2003 Posts: 6 Junior Member | | Junior Member Joined: Sep 2003 Posts: 6 | so, i've been busy, and i've been riding the bus. the gas cap was not the issue. this weekend i'll wrangle some time and pull the tank and double check the strainer. an interesting side note, since changing the pump, it actually takes less time for the truck to fail. i was getting 5 miles before, now i'm down to 2 miles tops. | | |
#49223 09/13/2005 8:50 PM | Joined: Aug 2005 Posts: 16 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 16 | My 61 was doing this same thing recently. With the help of the stovebolt forum crew, I found that it was indeed the strainer on the fuel pickup in the tank. Changed it out, runs like a top. | | |
#49224 09/13/2005 10:15 PM | Joined: Sep 2003 Posts: 6 Junior Member | | Junior Member Joined: Sep 2003 Posts: 6 | | | |
#49225 09/16/2005 2:44 AM | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | On my 49 it was a clogged fuel line [rust],changed to rubber line,no problem.
Floyd
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | |
#49226 09/16/2005 4:35 AM | | Anonymous Unregistered | | Anonymous Unregistered | Im not sure about your 58, but my 53 had the same problem. I managed to crawl under it with a piece of wire and a cresent wrench. There was a valve that comes out of the bottom of the tank under the cab. I pulled it out and gas was only dripping, I stuck the wire in, got soaked in gas but never had the problem again. Good Luck. | | |
#49227 09/16/2005 3:06 PM | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I'd drain all the gas out of the tank, pull it, then flush and seal the tank.
Even if that's not the problem, it will be some day.. it's something that should be done with any vehicle 40+ years old IMO.
Since it actually starts and runs a few miles or so before it starts acting up, I wouldn't suspect a clogged fuel line, since if there was enough crud in the fuel line to stop the engine, it would probably run like [censored] from the get go.
Inline fuel filter between the pump and the carb is a must have, as well. If you don't already have one, get one.. if you've got one, replace it.
With a clean and sealed tank, a new fuel pump, and a fresh fuel filter in line between pump and carb you fuel system should be good to go.
You probably have crud floating around in the gas tank.. as gas is sucked out of the tank by the fuel pump, this crud collects and finally clogs the flow. When the engine is shut off, the crud floats away and flow is restored.
You said with the new fuel pump the problem actually got worse.. which makes sence. Increased suction would mean that crud gets sucked to the "clog point" faster.
Sounds like natures version of the old pingpong ball in the gas tank trick.
