| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | Hello, new to the group, looking for some help...
How do I hook up the three wires on a three-wire alternator? And what do I do with the old wires coming from the old voltage regulator?
Is there a web site with wiring diagrams for 12v conversions of the 216 that would help? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Funton,
Welcome to the Stovebolt...great handle! If this is on your '53, the process is pretty straightforward.
The alternator, if it's a three wire SI, or internally regulated unit, will have a small DA plug with two wires, and a large power wire. The large power wire ( BATT) can be connected to the wire from the old BATT terminal on the voltage regulator. This will route power through the ammeter so the system reads as it did before.
The small wire from DA#2 can wrap around and connect right to the large terminal..BATT on the alternator itself.
The other small DA wire marked #1 needs to be connected to a switched source of power. This would be a terminal on the key switch itself. Your key switch should have two switched terminals...either one will work.
The two remaining wires on the old voltage regulator would have been ARM and FIELD (I think). These can be removed or just taped up and left for posterity...they are no longer used.
Be sure to address the other areas when switching to 12 volts. These are things like lamps and voltage reducers for a few critical items. Good luck.
Stuart | | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | Thanks atomarc, I think I can hook it up now. | | |
