The 4200 uses a multitooth cam sync signal to generate cam position and cam sync to tell the PCM if its on cly's 135 are ready to fire or 246. Great if your running the GM electronics.
The lower end aftermarket ECM's usually expect a 0 or 1 signal from the cam sensor not multiple teeth and usually don't have the capability to run the VVT so I needed to do something to get the right signal. Also the adjustable cam sprockets didn't have a provision to press in the cam drive dowel pin.
So all this got fixed after I made this hub that replaces the VVT actuator and its multitooth cam signal hub:
[IMG]http://img407.imageshack.us/img407/565/p1100550ek7.th.jpg[/IMG]
