9 members (3B, Johnny Rib, baldeagle, 68ironhead, 2-Ton, 1955 1 Series, JW51, Guitplayer, walter74),
108
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 16 New Guy | | New Guy Joined: Nov 2008 Posts: 16 | Well it's time... the need has arisen and we need some air tools. I've got a few questions: 1) What PSI/stage/brand compressor do you recommend. I'll only be using tools for short periods of time and not at the same time. My grandfather who owned a full fledged shop suggested a 5 HP or more, 150 PSI, 2 stage compressor. This seemed like a little to much. 2) What kind of tools should we get? I certainly need a nibbler, grinder, wrench, air file. Any others?
Thanks all. This will really help us out. | | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I'd listen to Grandpa. Die grinders and DA sanders are air hogs. You eventually may want to get a blast cabinet and they also use a fair amount of air. An air compressor is kind of like a welder--a big one can do a small job but a small one can't do a big job. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | An air compressor is kind of like a welder--a big one can do a small job but a small one can't do a big job. Well said!  Bruce | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | For the type of work you are going to do get as big a compresser in 2 Stage as you can aford. I have a 2 Stage and it's 165 PSI. MAX. 5HP. 220 Volt rated @ 18.8 CFM @90 PSI. 60 Gal. Vertial Tank. Running a HF. Sand Blaster I can take this 2 stage down if I push it hard but havent had any problem with air tools yet. The 2 Stage is a great unit from HF. contrary to some who think they put out junk tools. For home there is no need to spend $2500.00 - $3000.00 on a compressor for home use unless you will use it day in and day out. I have had this compressor 2 years and had a bad compressor when it was brand new but I think it was not properly torked on the rod bearing at the factory. They sent out a new unit and got in in 2 days. When I offered to send the other back they said keep it for parts down the line. I HAVE HAD ZERO PROBLEMS SINCE! I have worked the snot out of it in 2 years being retired. Almost forgot I gave $599.00 plus tax out the door and I have got my money out of it in saved labor. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | In my humble opinion,you can never go too big on a compressor.I bought a 5 Hp two stage Ingersol Rand on a 80 gal. tank. It has done a good job for me.I found the best deals for me were at Tractor Supply.Course I am sure you will recieve many different opinions here. | | |
