3 members (Gdads51, Bill Hanlon, Otto Skorzeny), 65 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#491729 01/10/2009 6:30 AM
Trying to figure out the rear cab mount on the 47 3/4 ton.
The center mount is an obvious rebuild with the new bushings but the outer mounts are gone except for a few flakes of rust. The new teardrop bump stops have a 3/8 mounting bolt which is different than what was removed. The rebuild kit is from Classic Parts.
Do I need to fab a new bracket to mount the bump stop or do I drill a hole in the cab floor to mount the bump stop above the frame? How much clearance should there be between the fame and bump stop?
Jim
The tear drop bump stops are not the orginal shape , but they will work. Drill holes in the cab floor to mount the stops. They should touch the frame, not tight, just touching. Their purpose is to limit the side to side sway. I used hockey pucks on my '48 with some shims to bring them in contact with the frame.
Thanks for the help. I had to tig the ceter mount back together and wanted to be sure I wasn't missing something with bump stops.
Jim
