| | | Forums66 Topics128,082 Posts1,055,961 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 53 | Trying to figure out the rear cab mount on the 47 3/4 ton. The center mount is an obvious rebuild with the new bushings but the outer mounts are gone except for a few flakes of rust. The new teardrop bump stops have a 3/8 mounting bolt which is different than what was removed. The rebuild kit is from Classic Parts.
Do I need to fab a new bracket to mount the bump stop or do I drill a hole in the cab floor to mount the bump stop above the frame? How much clearance should there be between the fame and bump stop?
Jim | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | The tear drop bump stops are not the orginal shape , but they will work. Drill holes in the cab floor to mount the stops. They should touch the frame, not tight, just touching. Their purpose is to limit the side to side sway. I used hockey pucks on my '48 with some shims to bring them in contact with the frame. | | | | | Joined: Mar 2006 Posts: 53 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 53 | Thanks for the help. I had to tig the ceter mount back together and wanted to be sure I wasn't missing something with bump stops.
Jim | | |
