3 members (Hotrod Lincoln, baldeagle, Lightholder's Dad), 42 guests, and 5 robots.
Topics128,018
Posts1,055,339
Members48,419
#491515 01/09/2009 6:22 PM
any mysteries I need to know about on replacing a fuel pump on a 235? looks cut and dry, but didnt know if a zillion springs or something fly out of there when you remove the old one.
56 stepside 3/4 ton longbed
56 stepside,
The topic mentions fuel pump...your post says fuel filter. I'll bet you mean fuel pump.
This task is easier if you use a couple of long bolts with the heads chopped of as dummy alignment tools to slip the pump and gasket up to the block.
It isn't 100% necessary, but because the actuation arm will push on the cam lobe, it tries to tweek the pump, and it's difficult to push it up to the block and get the bolts and gasket aligned.
Do a dry run and you will see what it's all about. One mans difficulty is another mans piece of cake. Good luck.
Stuart
56, Tie the gasket to the fuel pump with thread from the sewing box ( right thru the top of the boltholes) - getting everything aligned is much easier! When the bolts are started , you can either leave the thread or break it and remove it.
Glenn
Ex Hall Monitor
Ex Hall Monitor
It's pretty straight forward. As noted above it can test your patience because the pump lever holds the housing out a bit. You can use Glen's trick with the thread or simply put a bit of gasket shellac on the pump side of the gasket to hold it in place. I get one bolt started so the pump doesn't flop around while I start the other. I run the first bolt in just far enough to compress the pump lever a bit to make aligning & starting the second bolt easier. You'll get it. It isn't that difficult, about a 2 on the 1-10 scale.
easy work, even a 67 yr old man can do it.....takes about 8 min.
Redryder pix
My Hotrod
If I might add a couple things....I like to pack the inside of the fuel pump (where the actuator lever is pinned) with some grease and secondly, I prefer #2 Permatex sparingly on both sides of the gasket for no leaks. Mineral spirits will clean up your fingers!
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
Dave
got it thanks for the help
