| | | Forums66 Topics128,057 Posts1,055,812 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 22 New Guy | | New Guy Joined: Oct 2008 Posts: 22 | Will it weaken my frame to much if I cut out rear engine crossmember on my 62 Panel ? Its in the way for my 350/350 engine swap. Or is there other options I can use to get this done ? Thanks TOM | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Tom 1954, are we talking about a 1/2 ton frame with the "X" member in the center? If the crossmember is used solely for the engine rear support, and not involved with the suspension, then I would say you could remove it. | | |
