1 members (TexasJim50),
119
Mod | | | Forums66 Topics128,265 Posts1,058,364 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | I have a 66 Suburban, and at the base of the 4 Speed Shifter, is a round electrical switch that is activated by a lever on the shifter itself. I am assuming that this is for the back up lights? I have looked at a couple of new parts sites and checked with a used supplier, and have come up with nothing. Is this a factory item, and are these available somewhere? | | | | | Joined: Aug 2003 Posts: 65 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 65 | That's the way they were built. I don't know whether they are still available.
51 Chevrolet Canopy Express 02 K25 Duramax Crew Cab
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Don't remember but it is probably what is called a momentary switch, "normally off" type. There are many switches that would probably work. the mounting will be the biggest thing to match. if you send me a pic or two of the switch I will find you one. Be sure to send a pic of it mounted also. I had a 66 Suburban and fixed this switch but that was 5000 sleeps ago. I would try a dealer just in case.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | like this? - check here, 66-90 back-up light safety switch, 4 speed ... prolly would be available at a dealer or Flaps Bill | | |
