4 members (Sjm, TexasJim50, Chris_Welch, 1 invisible), 103 guests, and 4 robots.
Topics128,267
Posts1,058,386
Members48,485
#491433 01/09/2009 1:09 PM
I have a 62 with the tank still behind the seat. A while back I replaced the fuel sending unit and gasket. Now it seeps fuel when the tank is full. Is there some sealant that I can use that is safe with gas. I thought that I had heard somewhere that silicone would not work with gas. Any suggestions would be helpful.
By the way, it had the same leak before I replaced the sending unit. The tank does not appear to be bent or tweaked in any way. I think its coming from around the screw holes, and yes they are tight.
thanks
Darin
use PERMATEX on tne screws and the gasket on the float.this will solve your problem
dan-pa
thanks Dan
62,
Just my 2 pennies, I have used most all of permatex's products an I find that ya just cant beat the Black #16B, I prefer it over there Blue Glue an other products for its durabilty and Durometer it achives when it cures.
You can pick it up at any NAPA, just make sure to REALLY clean all your mating surfaces with laquer thinner or acetone..so THEY ARE CLEAN!..an let the Black cure very well at least a good day before puttin the gas to it an you will end up with a NO LEAK SITUATION!
Tim
1952 Chevy Shortbed
Photos in Photobucket
thanks for the info sw
Ultra Copper RTV is my recommendation, works best sealing petroleum stuff (gas, oil, etc.)
there is also a sealant called Seal-All which is specific for gasoline
I'd go to my local home improvement store or hardware store and get a can of pipe thread sealant. Make sure its for use with gas lines, water, steam ect. I've had the best results using this type product for these kind of repairs. A little bit of it goes a long way.
thanks for all the help guys
