1 members (J Lucas),
102
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 51 | I have a saginaw 4 speed on my 53 1/2 ton. I'm installing a new modern master cylinder w/ a CCP bracket. The Patrick's shifter blocks any brake lines going to theright side{inside by tranny} of the cylinder. Is there a GM master cylinder I can get that will allow me to plumb into the outboard side? Even that will be tight with the bracket kind of in the way, but I'm thinking maybe brass fitting could bring the lines down a little. Any help?
[url=http://www.stovebolt.com/gallery/shannon_joe_1953.html]1953 Chevy 3100[/ur When life looks like easy street there is danger at your door
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy joethehuman, there are some master cylinders with the ports configured out to the right side [when viewed from the rear]. Is this going to be a drum/drum, or disc/drum setup? | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | MP Brakes (Master Power Brakes) makes one like you need. Their site is at: http://www.mpbrakes.com Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | There are plenty of MCs that are made with the ports on bboth sides. If you are running disc/disc or disc/drum, you will likely need a combination valve. Which way the lines exit the MC becomes moot with a combination valve. | | | | | Joined: Sep 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 51 | This is for a drum/ drum application. I'm taking the mastercylinder back today and will see if they have one with ports on the opposite side or both sides. This one is for a 76 GM half ton.It was around $35 for new not rebuilt. Thanks
| | | | | Joined: Sep 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 51 | Well, it's been difficult routing the lines to the M/C. I got a M/C with the ports on the outside frame side to avoid the Patrick's shift linkage on the saginaw. But the front port on the M/C is so close to the bracket that I think I neeed to drill a hole thru it to route the line from the front brakes. that should work.So new bends in the lines and a T and short line thru the new hole to the M/C. Then I'll be home free.
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Joe, It is a tight fit with the lines facing the saginaw 4 speed shifter but it can be done. What you do is thread in the lines, tighten up then do severe bends, make sure you put in 10 lb residual valves at a minimum close to the master cyl. You need residual valves because the master is level or below the wheel cyls. I've got a 52 with the same set up, well until I changed to disks up front. There you'll find the disk / drum master cyl bigger but it can be done also. Good luck.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
