9 members (Bill Hanlon, Otto Skorzeny, 50Chevy3100, cmayna, UnclePaddy, Tronman, TUTS 59, 2 invisible), 104 guests, and 3 robots.
Topics128,042
Posts1,055,509
Members48,424
#49126 08/16/2005 9:51 PM
OK, I know this has probably been answered by someone for someone else at one time in the past, but...
I've got a line on a '54 235 engine, complete, out of a one-ton Chevy, from air cleaner to oil pan, fan to flywheel. It also includes the clutch assembly and bellhousing. NO tranny. This is out of a one-ton that had a four-speed.
Will this whole assembly fit my son's '46 1/2-ton without a lot of drama??? What needs to stay? What needs to go? What needs to be modified to fit?
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
#49127 08/16/2005 11:20 PM
Jed Offline
Patrick, Check the tech tips at the top of the page. I believe it's covered there in pretty good detail. Also, check out Bowtie Bits website. They have an article out there that I believe explains exactly what you're looking for.
I guess you must have decided to keep it?
Good Luck with the project.
#49128 08/16/2005 11:57 PM
Patrick - Keep the bellhousing and trans from the 46 and the whole thing will slide right in and bolt right up. You might have to go to a short shaft water pump, but that's it.
Have fun
George
#49129 08/17/2005 1:15 AM
54 was the last year for the short water pump (except 55 first series) so this motor is the one you want. I'm running one in my 53 flatbed.
1946 1/2-Ton Chevy
#49130 08/17/2005 2:45 AM
Cool, guys, that's what I need to know. This is a low-mileage rebuild that is absolutely complete, and a day's drive round-trip. The more I fart around on this truck, the more I want to keep it, so I'm leaning towards hanging on to it for me and giving my '71 Dodge D-100 to my son to drive.
#49131 08/17/2005 5:33 AM
you just want all the fun
