BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
2 members (Mike Lee, LAROKE),
439
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Oct 2008 Posts: 24 Apprentice | Apprentice Joined: Oct 2008 Posts: 24 | Hello,
I have a 1952 Chevy 3100 and have to install the door hold open springs. I got two pairs from a parts dealer. But... how do I have to install them ? Has someone a photo where I could see it ? I have no idea how this should work.
Thanks for your help
Tom | | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | | | | | Joined: Oct 2008 Posts: 24 Apprentice | Apprentice Joined: Oct 2008 Posts: 24 | Hi Tim,
yes, this is exactly what I mean. Seems not to be very easy to get the spring into the latch...
Thank you !
Tom | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | There is a tech tip here on rebuilding a set of hinges. Those are menioned in the tech tip. You will have to take the hinges out and while out you may want to change the pins if there is any wobble/wear. Those little boogers are sort of tricky but if you'll read the tip and them play with them a little you will see how they go and it will be a little easier. | | | | Joined: Oct 2008 Posts: 24 Apprentice | Apprentice Joined: Oct 2008 Posts: 24 | Hi Alvin,
thanks for the tip. But I didn't find the tech tip regarding hinges.
But I found out, that the easiest way is to remove the bolt at the hinge and then it is easy to get the springs in. But it is not so easy to install the hinges with the springs back to its place. Because the base of the hinges are now a bit wider.
By the way, the parts you sent me arrived, thanks for you help and : Happy new year !
Regards
Tom | | | | Joined: Sep 2001 Posts: 29,262 Bubba - Curmudgeon | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,262 | This is not an official Tech-Tip; it's part of the excellent "Basics of Basics" series by MARTINSR. Maybe this is what Alvin is referring to? | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | tclederman: your absolutely right. After I told Tom it was a tech tip I went to look so I could put it here but didn't find it. I just thought I was sleepy!! I printed out all MartinSr. instructions with the pictures and they help me along. Mine are already back on the panel but the doors are not aligned yet. Thanks for keeping me Straight!
Tom, thanks and hope 2009 will be agood one for all of us. | | |
