| | | Forums66 Topics128,066 Posts1,055,871 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#49104 08/16/2005 4:42 PM | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | Hey guys.. i've done quite a bit of searching, but haven't seen this answered, or i just plain missed it. when putting the new x-member on, do you have to do something to keep it true to the frame, or do some existing holes line up so that you dont have to worry about the alignment?
I'll likely be getting a free 84 pickup donor here pretty soon and will be doing the swap with mc/booster and wanted to have my ducks in a row..
Thanks! Shawn
1966 SWB
#49105 08/16/2005 8:10 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Your Question isn't very clear. I don't see why you should have to have a new crossmember when you change mc/booster. But... The main thing about changing the cross member is the alignment of the driveline. The output shaft of the tranny has to be parallel to the pinion shaft within a few degrees. There's a good article about it at http://www.classictruckshop.com/driveline.asp . | | |
#49106 08/16/2005 8:34 PM | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | sorry, Not just for that, I'm swapping in the crossmemeber for the disc brake stuff.
1966 SWB
#49107 08/16/2005 8:45 PM | | Anonymous Unregistered | | Anonymous Unregistered | Your answer still did not clarify things welk. If you are talking about the front crossmember for an IFS kit then its alignment to the frame is critical or the truck with drive sideways. Your IFS kit or crossmember should have come with instructions. If not then contact the supplier to obtain them.
If this is for your 66 I would have to ask why you are changing the cross member as you can just replace the spindles. | | |
#49108 08/16/2005 9:01 PM | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | Ok..
I have a 66 pickup. I'm getting a 84 parts truck. I want to swap the whole front crossmember in so i can have better brakes. I know you have to drill some holes in either the crossmemeber or the frame to do the conversion. Do any of the existing holes line up already?
1966 SWB
#49109 08/17/2005 2:25 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I can't answer that question. I thought you were talking about the tranny crossmember. | | |
#49110 08/17/2005 11:33 AM | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | That's cool. thanks anyways! I guess i've been assuming everyone knows i'm talking suspension since that's what i've been looking into for the past couple days
1966 SWB
#49111 08/17/2005 2:37 PM | Joined: Feb 2005 Posts: 60 Member | | Member Joined: Feb 2005 Posts: 60 | Yep a couple do line up. I think you need to drill 2 or 4 more. | | |
#49112 08/17/2005 5:03 PM | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 |
1966 SWB
#49113 08/17/2005 6:02 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you do a search for IFS or independent front suspension you might have better luck finding what you're looking for. | | |
#49114 08/18/2005 2:52 AM | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | on the crossmember ten bolts line up,four need to be slotted.use the 84 steering.you will have to drill two new holes for the newer idler arm,otherwise it bolts on.you will need the "rez" kit to bolt on the power steering box. | | |
#49115 08/18/2005 7:16 AM | Joined: Jul 2005 Posts: 24 Junior Member | | Junior Member Joined: Jul 2005 Posts: 24 | Cool thanks. The truck has power steering already..
1966 SWB
