7 members (Joe H, JW51, Millenimech, dt235sd, Eisenholtz, klhansen, Ponchogl), 109 guests, and 0 robots.
Topics128,051
Posts1,055,764
#490663 01/07/2009 2:50 AM
Does any one know if the front fenders on like a 49 chevy 6400 or 4400 interchange with a half ton or not i don't think they will but someone on here would know more then me
The fenders on the 4400 and 6400 are wider and longer with a larger wheel opening than the half ton through ton trucks. Hope that helps.
Jon
Only the cabs will interchange.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
Yeah it does thank you. If you have any more tips that would be great. my boss and i are starting to rebuild his 49 chevy 6400 and hopefully this spring i can start rebuilding my 49 chevy 4400 which i purchased last weekend
If you're looking for replacements for either truck, there is a whole front clip listed in the freebie section of the swap meet.
David Colter
I know they are wider than the 3100, not sure about longer, however here is a pic of a big-bolt front clip on my 3100. pic
I got the clip for a good price and it matches the parts I picked up for Frankentruck. The wider fenders will help cover the wider tires I plan on running.
62401
crzyrdneck -- Be sure to check out our Tech Tips for more info on restoration (We have a lot of Big Bolt stuff in there, too).
I'm about 85 percent finished on a frame off resto of a '49 4400. I'm no expert but but a lot of the guys here are, so keep those questions coming and we'll help you get through both trucks.
And welcome to Stovebolt.com, by the way!
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
