| | | Forums66 Topics128,266 Posts1,058,369 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | not sure if this is the right pace for this post but here it goes. I will be painting my truck (37 GMC) this month. Are there suppost to be any rubber pads between the cab and frame and I don't think the very rear cab mount is wood. Could somebody let me know what it is suppost to be and where to get it.
1938 Gmc 1/2 ton
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If you want to stay stock, there are wood blocks / pads between cab & frame. Try Jim Carter Truck parts, or Chevs' of the 40's. Mine is rodded - used hi-density plastic material. | | |
