1 members (Greg_H),
98
Mod | | | Forums66 Topics128,081 Posts1,056,319 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Guys, I need some feedback from folks who have converted their truck's rearend with that new 3.55 assembly. Is it worth the 400$? | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | From what I have seen it really is. And my truck sure needs it. I really don't like the rpm's it runs on the freeway.
BTW, did you see that Whizzer panel truck posted in another thread?
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | | | | | | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | | | | | | Joined: Aug 2002 Posts: 455 Shop Shark | | Shop Shark Joined: Aug 2002 Posts: 455 | Got mine two years ago - best investment and improvement yet. Especially going down the freeway. Makes the engine happier too - lower RPM at same speed. Go for it - Unless you need your truck for pulling tree stumps... | | | | | Joined: Aug 2001 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 47 | I've been running the Patrick set up with the Saginaw 4 speed conversion. It works great. However you may want to investigate the use of a 5 speed out of a S10. | | | | | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | Installing the 3.55 rear wasn't worth it for me, but only because I didn't do my homework. I changed too many things at the same time. First off, I changed from a really tall (7.50x16) tire to a much shorter low profile tire to get the truck to sit lower. Net gain: nothing, in fact maybe even more RPM at cruising speed. Only after changing to an overdrive transmission and later 3.90 open rear did I get down to a comfortable cruising RPM - about 1900 RPM at 60 MPH.
Granted, with a stock Stovebolt a 15% reduction in RPM is better than nothing. You will be turning 2600 RPM instead of 3000 at the same highway speed. My experience, though, is that you need a more dramatic reduction in RPM to really be in the comfort zone of these old long stroke motors. When you get into building a more high performance engine with better breathing and more cam, the whole equation starts changing again, and you have to be aware of where your torque peak is and what gearing you need to optimize response at any given road speed. So to answer your question - it's a qualified "yes" but, plan ahead. | | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Whizzer, You have a nice original truck . The Patrick's gears would not change the look and would certainly allow you to enjoy driving it more..
Those 3:55's are the best money I spent on my truck. Spend the cash, do the work, and enjoy the ride...
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
| | | | | Joined: Nov 2001 Posts: 122 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 122 | I was considering doing this also for my '54 GMC but I was told unless you "really" know what you're doing there was too much of a chance of messing it up. Is this true or is that an old wives tale? Would someone with limited mechanical knowledge, such as myself, be able to bolt one in and do an acceptable job? How hard a job is this? Thanks! :confused: | | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | 54, You can do the job if you are patient and can follow directions. You do need a dial indicator, there is no room for guessing when setting the clearance between the ring and pinion.
Patrick gives good detailed directions and will gladly help you out on the phone if needed..I found the shop manual to be helpful also, don't start the job without having one open on your workbench..
| | | | | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | My1 ton farm truck is not ready for road testing, but I think I will have to change my rear end gears. Where can I get more info on the 3.55 greplacement gears and who sells them | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I too, have the patrick gear along with the 4 speed saginaw conversion, truck runs really well,has howard cam also. real quick even with the 1 barrel carb, the 4 speed conversion works well,although at times on the interstate, IT FEELS LIKE IT COULD USE ANOTHER GEAR OR OVERDRIVE, my TRUCK is a daily driver and I have ran it 5 yrs without any problem, other then the problem with it dieing a while back, You guys helped out, I thouhgt it was the carb, had it rebuilt by recarbo. they did a good job but as a stovebolter suggested, the problem ended up being in the ballest(firewall coil resistor) that $4 part almost drove me crazy. sorry I got off the subject, It is a good deal.---- Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Fritz, I don't think they are available for the 1 ton.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | On the 3/4 and 1 ton models, this has been documented pretty well by Oldcarkook on his web site. | | | | | Joined: Jun 2001 Posts: 34 Member | | Member Joined: Jun 2001 Posts: 34 | I have a 53 1 ton panel. I changed the rear pumkin to 4.10,run 235/85/r16's and swapped in a T5 from a Camaro. I rebuilt a 261 and have a holley/weber 2bbl on it. I run 1900 at 55mph and with 2100 miles on the truck I'm getting 13-14mpg in town and 17-18 on road trips. Clutch and tranny cost about $250 and the rear end was $150. Most of my driving is at 45-50mph with rpms in the 1500-1650 range. I guess you just have to balance costs vs. labor time. My setup was an easy job. | | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | Am I correct that this conversion to 3.55 is intended for those with an enclosed driveline and 4.11 gears in a 1/2t ?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | What are you guys doing for better breaking when you get your AD's going at freeway speeds (70+ MPH?)? I remember drum brakes fading and doing absolutely nothing when trying to stop. It scared the heck out of me. I'll be installing a dual reservoir master cylinder and new break lines but that doesn't solve the fading problem. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | my brakes work real good, I just pay more attention to what I am doing when I drive the truck.....Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Am I correct that this conversion to 3.55 is intended for those with an enclosed driveline and 4.11 gears in a 1/2t ?
cmayna, That is correct...
| | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | 53 4 ME, Thanks for the clarification. Since I'll need to get another torque-tube driveline setup (which I've just found locally here in SF Bay Area)I might go the Patrick's route before I install the 3:55 before installing in my beast.
Craig
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | The brakes in my truck work as good as any brakes I ever had. Actually better than the ones in my 87 Fjord. (When it was still running). But I drive my truck like I drive all trucks with safety and stopping distance in mind. Also, I am not planning to go 70mph, but 55 to 60 cruising speed would make me feel a lot better on CA freeways.
Brake fade usually doesn't happen until the brakes have been used several times in a row without allowing a chance to cool. Go slow when you come down out of the mountains and don't ride your brakes.
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | P.S. Hey Craig, are we on for the March Goodguys? My turn to buy breakfast, you buy the beer...
| | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | Oh boy....Just came back from that wild 49er game. My heart is still pounding...
I agree with Tony M and other about the brakes. All I want is another 10 mph faster. As little as I use the freeway, I'm not too worried about braking. Besides my brakes work better than my regular family cars.
Tony, Your're on, though I might not have my truck with me since I'm seriously considering tearing my truck down for a new paint job and chrome job. Nevertheless, I'll be there.
Craig
