1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#49048 08/15/2005 2:55 AM
Hey guys, I won a McGurk tri-carb intake off Ebay. The seller said it would fit 216 and 235's. I dont know much, but thought I heard somewhere ( stovebolt probably!) that the intakes arent inter changeable between motors. Is this correct? How do I tell the difference?
#49049 08/15/2005 4:30 AM
wink
If I'm not mistaken, I think I saw that McGurk on eBay. It's the big four piece, three carb one - right? If so, that one will bolt up and work on a 216, 235 and 261. That intake will not, however, mate up to your stock exhaust manifold and basically has no provisions for heat either by exhaust or by water. What kind of vehicle are planning to put the intake on?
Tom Langdon runs this kind of McGurk on his 39 Chevrolet Coupe and has adapted a water line to his to preheat the fuel before it enters the engine with a pipe that he welded across the bottom (front to back) which he runs heated water through form the engine to pre heat the fuel. Of course, you don't have to do that. You can run it without the heat, but you will still have to figure on either headers or do something with your stock intake to be able to use it with the intake.
They are good looking intakes and do draw the attention!
grin
Joe
#49050 08/15/2005 9:08 AM
Yeah , I have one of those , it was fitted up to a 216, the car drove REALLY well , the manifold is just a wall ornament in the shed now.
#49051 08/16/2005 1:35 AM
6cylindersovertexas,
You are right, it is a four piece deal, the three intake runners connect to the main intake body where the carbs mount. I was going to run this setup on my 56 3100. Its probably a little overkill for the motor, but I wanted it for the 'cool' factor. I love vintage speed equipment, be it old Chevy's or VW's. I guess I just long to live in those days!
#49052 08/16/2005 5:26 AM
I checked again and the tube Tom Langdon ran for heated water is on the back of the intake main "log" at the bottom. It would work if you did it that way. Tom could fix that up for you.
grin
It would be an attention getter on your truck.
Be sure the rear carb doesn't interfere with anything. The intake and the rear carb get real close to the firewall and possibly the shifting linkage. The carb may clear the firewall, but an air cleaner might not fit on the carb without hitting the firewall. :confused:
Joe
#49053 08/16/2005 5:45 AM
"MONGO"
"MONGO"
Yeah, measure close and watch that firewall clearence, or you'll be doing like me and trimming your firewall back.
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
