0 members (),
50
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | Anyone know where I can get a 11 or 12 pin electrical connector. Male and female plug with pins that I would terminate to the wires. I got a steering column for my truck but it does not have a connector on it for the wires. The column has 11 wires. Has 3 wires that do not need to be terminated.
Thanks! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Chris,
McMaster Carr, on page 751, has pin and sleeve connectors up to 12 pins (poles). They are cool looking things you assemble yourself.
Maybe not what you had in mind, but take a look...catalog page #751.
Stuart | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | molex any good wire shop electrical supply store, maybe radioshack http://www.molex.com/molex/products/listview.jsp?query=&path=cHome%23%23-1%23%23-1%7E%7EncCRIMPHOUSINGS%23%230%23%232vc&channel=Products&
you can cut the ears off Part Number: 0003061122 Status: Active Overview: Standard .062" Description: 1.57mm (.062") Diameter Standard .062 Pin and Socket Receptacle Housing, 12 Circuits, Without Mounting Ears
Part Number: 0003061092 Status: Active Overview: Standard .062" Description: 1.57mm (.062") Diameter Standard .062 Pin and Socket Receptacle Housing, 9 Circuits, Without Mounting Ears
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2007 Posts: 39 Apprentice | | Apprentice Joined: Jul 2007 Posts: 39 | If you have one of those car recycler places close by you can always go there. I am upgrading and creating a completely new wiring harness for my truck since I want certain options and I just went to Ecology and took wiring harnesses from other late model cars and used those connectors. It is a cheap and and all the connectors will be "standard" automotive. just a thought. good luck! | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | Why not keep it Chevy? All the '70s and '80s "C" trucks, (and probably cars, too,) have a multipin firewall plug for the harness. It should work fine and might even have the same color codes as your column.
Best wishes,
Les | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | I will see if I can find a gm connector when I go to the local u-pull-it yard.
Thanks! | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I would go to your local Car-Quest or tractor place and get a few 6-pin pacard weather pacs cheep. If not, check any electrical supply house for Deutsch connectors (Distributed thru LADD).
