3 members (Steelonsteel, Woogeroo, klhansen), 154 guests, and 3 robots.
Topics128,186
Posts1,057,317
Members48,469
Junior Member
Junior Member
Anybody know where I can find (or have made) the rear portion (after the carrier bearing) of the driveline for this pickup? THANKS!
My 3800 isn't a pickup, it's a dual-wheel 1-ton with a stake-body flatbed. How long is your rear driveshaft?
Junior Member
Junior Member
Oh yea; that's the same as what I've got. I don't have a bed on mine; going to need to make one, I suppose. is there a bed for a 3800?
My 3800 is a panel.
If you want to drive over and take it off, you can have the driveline from under mine.
I-90 west until you hit the water. 35 minute ferry ride, and about 5 more miles. I should look under and confirm its still there...
Junior Member
Junior Member
I'd love to talk to you about that! I could piggyback a visit to the in-laws in Olympia on a trip like that. Are you parting out your panel? I'll send you an email direct....thanks!
If his is the wrong length or has other problems, email me. I'm parting out a 59 model.
Junior Member
Junior Member
I measured from the center of the carrier bearing to the center of the u-joint at the front of the differential and it's 56". How does that size up with what you've got?
