0 members (),
151
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 53 'Bolter | | 'Bolter Joined: Jun 2002 Posts: 53 | My /70 C-10 hasn't been driven in a while and I finally got it running pretty well and registered. The 3-on-the-tree shifter is very stiff. It moves up and down fine, but the forward-backward movement does not move well. What is the best way to free up the shifter? I have tried spraying the shift mechanism under the dash but it has not loosened up any. Can I get at the shifter rod without major disassembly of the steering shaft.
53 Dumpy
1951 Chevy 3100 "Ernestine" 1970 Chevrolet C10 "Ol' Blue" 1940 JD "long-hood" B 1959 Jeep FC-170 1960 IH B275 2013 Chevy Silverado 2023 GMC Denali 2500HD
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You need to take it easy on pulling the shift lever back and forth so you don't break off the tip. If it was mine I would take a punch and drive the roll pin out and take the lever out of the column. Then take penetrating spray with the hose on the nozzle and spray some down into the pin that is inside the column. After spraying it a few times put the lever back in and see if it gets better. You may have to do it a few times to get it smooth. | | |
