7 members (moparguy, 55shaker, BC59, Shaffer's1950, Joe W, 2 invisible), 79 guests, and 3 robots.
Topics128,185
Posts1,057,281
Members48,467
Ok, I mostly deal in the Bias ply tires.
I am setting up my coe for real work. The tire size on it now is [color:#FF0000]850x20
So, The question is. What Size or Sizes do you run one your big truck?
I am mostly interested in the 20 inch rim. ohwell
I can not locate a converter to convert the bias ply size.
thanks yahoo[/color]
Poets Seat Auto
Appraisals, Parts, Service
Past: General Motor's Master Technician
Member: Northeast Chevy/GMC Truck Club
Phone Number: 413.774.5856
Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
You don't really need to convert if you're keeping your stock 20" rims if I'm understanding you. This Yokohama online catalog shows 20" radials for bias big truck rims. They're on page 42. Stu
http://www.yokohamatire.com/tires_commercial/truckBusRefGuide.pdf
Just from the breif checking I've done just now, looks like a 9.00-20 would be the closest to that size. One thing you'll want to watch for is that the tires are compatible with your rims, you won't want to try to run tubeless on split rims, you'll need tube type in that case. You might consider swapping to a modern single peice wheels.
Bill Burmeister
Big Bolt Shop Curmudgeon
I am running 7.52 x 20 tube tires on my '46 1-1/2 ton.
The local tire dealer can get them. As long as you don't have to worry about heavy loads or long distances, practically any manufacturer's tire will do. Just check 'em frequently and make sure the pressure is correct.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
My local dealer I use did not have a cross over. but, said he would check. This truck will be a working truck transporting whatever on a gooseneck. and that trailer will have radials so. I have to have modern tires.
I would change out the rims but, they are very costly. Maybe down the road.
thanks
Poets Seat Auto
thanks truckdog. for that link I will call a dealer for pricing. There is no dealer where I live but there is one about 16 or so, miles away which is not bad.
Thanks for the input others have posted.
I have to keep in mind that this truck will be towing a Trailer with a max load at 14,000 pounds plus the trailer weight. so, I must have real truck tires.
Thanks again
Poets Seat Auto
My '53 6400 has 8.25-20 bia tires on it and they are plenty big on the front. I can see where the tires rub if the wheels are turned really tight. As long as bias ply tires are fresh they and have a proper load rating there is no reason that they are of a lesser quality than a radial tire. If you don't want to replace your wheels at this time your money is best spent on getting good bias ply tires for the rims you have.
24601
24601
We have a pretty good Tech Tip in the Tech Tips section (of all places ...) that Grigg wrote on just this very subject -- you could start there. He has some pretty good suggestions for further research, too.
Just click on "Tech Tips" in the menu bar at the top of the page. Or Click on this -- Tech Tips
Regards,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
