Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 52 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
#489489 01/03/2009 4:59 PM
Hi,
I bought a proportioning valve and booster from Jim Carter. Does anybody knows where the frontbrakes are connected to ?
There is 1 bigger connection at the front of the valve and 1 smaller at the underside of the valve.
I guess it is the connection that’s length wise of the valve ??
http://www.oldchevytrucks.biz/47_55/full.asp?page=56
Jan
Don't waste water, drink wine !
1946 Chevrolet 1/2-Ton Truck
The larger connector (1/4")is for the rear. The two smaller (3/16")are for the front.
Fred
The large one is to the front, the smaller 3/16 in on the side and only 1 connection.
Jan
Picture?
The ones I'm familiar with have 5 total ports.
One on the back center goes to the rear axle.
Two on the side/top are inlets from master cylinder.
Two at about 45 degree angle on the front are for the fronts.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Originally Posted by Grigg
Picture?
Grigg
Thats the kind I am using on my 37 GMC and that is how it is hooked up, but what is the wire for, is it the brake light switch and if it is how does it hook up to brake lights
1938 Gmc 1/2 ton
I understand the wire is for an idiot light on the dash, to show if one side lost fluid.
I have not used it.
Grigg
---All pictures---
Grigg #489945 01/04/2009 10:05 PM
I found a drawing, thanks,
Jan
