0 members (),
75
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,431 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I have a 37 GMC and am going to be painting it this month. I need to know what to do with the underside of the fenders so I don't get road stairs in them. Will something like rino lining work or is there something that is specificaly made for the underside
1938 Gmc 1/2 ton
| | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | You can get a pretty good idea of what I did by looking at my Fenders Album. You can see some more examples under the Cab and Running Board Albums. I had the fenders, running board undersides, and the underside of the cab coated with Line-X and am extremely happy with the result. Line-X is a bit finer in texture and povides a nicer finish in my opinion. Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | so is that linex about the same as rino lining and how hard is it to apply, does it work good at preventing road stars. Stars are the only thing bothering me about painting my truck
1938 Gmc 1/2 ton
| | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Yes, its about the same, only goes on a bit smoother. Now, mind you this is something that has to be applied by a franchisee and he parts must be off the truck. I doubt anything but a big railroad ballast type rock flung up would make a star. This stuff is very very tough. Mine was done after the painting was done which for some reason was the way the Line-X dealer wanted to do it.
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | have to see if I can find a linx dealer hear what kinda cost is it
1938 Gmc 1/2 ton
| | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Check my gallery entry and find the link to the cost spreadsheet. I believe I have the cost of doing each of the above mentioned components entered. Good luck.
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I paid $100.00 per fender done before painting, sprayed hot at thier shop with a finish thickness of.075". I went with Bulldog which is the same as Linex and other franchises using that system. As long as it has a lifetime warranty it's probably the same product. I'm extremely happy with the noise reduction and more solid feel a heavy duty product under there provides as well as it's great on runningboards. http://www.bulldogcoatings.ca/index2.htmhttp://www.line-x.com/
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I used por15 on the underside of the fenders, then primed the por15 and shot it with black paint. Seems to be holding up fine! | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | be sure and seam seal all little cracks and crevices. it helps prevent water and mud from going deep inside those areas.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 | You might look at www.secondskinaudio.comCheck out their Spectrum product, which is designed for underside of fenders, rear wheel wells and bottom side of the vehicle to reduce road noise, etc.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
