4 members (klhansen, Eisenholtz, homer52, Otto Skorzeny), 69 guests, and 4 robots.
Topics128,023
Posts1,055,371
Members48,420
#48973 08/13/2005 4:33 AM
Junior Member
Junior Member
This may seem elementary to most of you, but how many cubic liters does a 350 have? I was told 5.7, but Im not very sure.
#48974 08/13/2005 4:56 AM
Yes...approximately 60 c.i. per cubic liter i.e. 302 is 5.0 or a 454 is 7.4L. Hope this helps. later
Dave
Even a blind squirrel gets a nut sometimes!
#48975 08/13/2005 5:09 AM
I use Harley Davidson to remember this conversion. A Harley 74 cubic inch is 1200 cc's. A 1000 cc Sportster is 60 cubic inches.
So 350/60 = 5.83 which is close enough for mental comparisons, but not quite right. The actual converion is 1 liter = 60.7 cubic inches. 350/60.7 = 5.766 so we can see that Chevrolet appears to be rounding a little.
Either 5.7 isn't quite right or 350 is wrong in the first place.
#48976 08/13/2005 5:50 AM
1 cubic inch = 16.4 CC
1 Liter = 61 cubic inches
302 Ford = 4,952.8 CC Ford cheats 47.2 CC's when they call it a 5.0 Liter.
Chevy 305 = 5,002 CC. A real 5-Liter.
1 inch = 25.4 MM
1 MM = .039"
1 CC of water weighs 1 gram.
Additions to the list, anybody?
#48977 08/13/2005 6:10 AM
Insomniac
Insomniac
In the late 70's GM began referring to the 350 as a "5.7 litre V8" (at least here in Canada). However they still listed the bore and stroke as 4.0 x 3.5 (inches). I think the name change happened about the same time as they stopped displaying the engine size on the truck's grill.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
#48978 08/13/2005 6:15 AM
4" Bore
3.48" stroke
8 cylinders
Displacement = 349.6704 cubic inches. That's pretty close to 350!
#48979 08/13/2005 10:25 AM
Exactly 5.7354724
Here is a free online conversion site for
length, area, volume, wight, temperature and milage
http://www.volker-quaschning.de/datserv/us-rechner/
Frank grin
#48980 08/14/2005 6:09 AM
A cubic inch is so called because it represents a cube 1" wide, 1" tall and 1" deep. Thus 1X1X1=1 cubic inch. A liter is a measure of volume. There is no such animal as a cubic liter.
