| | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48973 08/13/2005 4:33 AM | Joined: Jul 2005 Posts: 1 Junior Member | | Junior Member Joined: Jul 2005 Posts: 1 | This may seem elementary to most of you, but how many cubic liters does a 350 have? I was told 5.7, but Im not very sure.
Thanks | | |
#48974 08/13/2005 4:56 AM | Joined: May 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 50 | Yes...approximately 60 c.i. per cubic liter i.e. 302 is 5.0 or a 454 is 7.4L. Hope this helps. later
Dave
Even a blind squirrel gets a nut sometimes!
#48975 08/13/2005 5:09 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I use Harley Davidson to remember this conversion. A Harley 74 cubic inch is 1200 cc's. A 1000 cc Sportster is 60 cubic inches.
So 350/60 = 5.83 which is close enough for mental comparisons, but not quite right. The actual converion is 1 liter = 60.7 cubic inches. 350/60.7 = 5.766 so we can see that Chevrolet appears to be rounding a little.
Either 5.7 isn't quite right or 350 is wrong in the first place.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#48976 08/13/2005 5:50 AM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | 1 cubic inch = 16.4 CC
1 Liter = 61 cubic inches
302 Ford = 4,952.8 CC Ford cheats 47.2 CC's when they call it a 5.0 Liter.
Chevy 305 = 5,002 CC. A real 5-Liter.
1 inch = 25.4 MM
1 MM = .039"
1 CC of water weighs 1 gram.
Additions to the list, anybody? Jerry
#48977 08/13/2005 6:10 AM | Joined: Jul 2000 Posts: 2,187 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,187 | In the late 70's GM began referring to the 350 as a "5.7 litre V8" (at least here in Canada). However they still listed the bore and stroke as 4.0 x 3.5 (inches). I think the name change happened about the same time as they stopped displaying the engine size on the truck's grill.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
#48978 08/13/2005 6:15 AM | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | 4" Bore 3.48" stroke 8 cylinders
Displacement = 349.6704 cubic inches. That's pretty close to 350! Jerry
#48980 08/14/2005 6:09 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A cubic inch is so called because it represents a cube 1" wide, 1" tall and 1" deep. Thus 1X1X1=1 cubic inch. A liter is a measure of volume. There is no such animal as a cubic liter. | | |
