0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#489649 01/04/2009 2:01 AM
JDM
Offline
Apprentice
Apprentice
Can any one tell me or where to find information on installing a T5 behind a 350, I already changed the rear end to a 12 bolt
THX John
a T5 may not be what you want behind a 350 V8 because of torque considerations, it may not be much help, but for some...
http://www.motivegear.com/tech_info/tranny_guide/tranny_guide.html
just as a side line look at SM465, NV3500 & 4500
But then again it ALL depends on what it is you want this truck for .. use wise...........
towing, race, show, lack of $$, general driving, hauling ???
visit inliners international http://www.inliners.org/ ... tech, tranny section
what the gear ratio of the rear end ???
Jim & Caroline
Stock or near stock small block shouldn't be too much of a problem. The T5 I have came out of an 85 Camaro V8. Granted it was a 305 but they were also used behind 350's in Camaro/Firebird and I believe Corvettes. If your not too crazy on the horsepower you should be OK.
Chuck
The T5 NEVER was behind the 350. The T5 has a limit of 300 lb-ft when it is the V8 Camaro or V8 Mustang transmission. Here is the TTC page on the T5 http://www.ttcautomotive.com/English/products/T-5.asp#Car
If you want heavier duty 5-speed, the NV3500 would be a better candidate than a T5 and fit without modifications. The NV3500 was found behind 4.6 V6's and 305's. ZF transmissions were behind the 350's in the 1/2T from 88 to mid 90's then the NV4500 was used
Riding in the Passing Lane
There is a lot of info in the Tech section of this website on installing a T-5 & you could do a search for past posts on it. It has been discussed many times in these posts. I run one behind a 350 & it works fine. As long as a guy doesn't do burnouts or speed shifts I think it will last from now on out. It is the perfect way to deal with the low rear end gearing of these old trucks. A lot easier then putting in an automatic & much more fun to drive.
1972 Chevy c10 Cheyenne Super
