| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 10 Apprentice | | Apprentice Joined: Jan 2009 Posts: 10 | Can any one tell me or where to find information on installing a T5 behind a 350, I already changed the rear end to a 12 bolt
THX John | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | a T5 may not be what you want behind a 350 V8 because of torque considerations, it may not be much help, but for some... http://www.motivegear.com/tech_info/tranny_guide/tranny_guide.htmljust as a side line look at SM465, NV3500 & 4500 But then again it ALL depends on what it is you want this truck for .. use wise........... towing, race, show, lack of $$, general driving, hauling ??? visit inliners international http://www.inliners.org/ ... tech, tranny section what the gear ratio of the rear end ???
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2006 Posts: 117 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 117 | Stock or near stock small block shouldn't be too much of a problem. The T5 I have came out of an 85 Camaro V8. Granted it was a 305 but they were also used behind 350's in Camaro/Firebird and I believe Corvettes. If your not too crazy on the horsepower you should be OK.
Chuck | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | The T5 NEVER was behind the 350. The T5 has a limit of 300 lb-ft when it is the V8 Camaro or V8 Mustang transmission. Here is the TTC page on the T5 http://www.ttcautomotive.com/English/products/T-5.asp#CarIf you want heavier duty 5-speed, the NV3500 would be a better candidate than a T5 and fit without modifications. The NV3500 was found behind 4.6 V6's and 305's. ZF transmissions were behind the 350's in the 1/2T from 88 to mid 90's then the NV4500 was used
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is a lot of info in the Tech section of this website on installing a T-5 & you could do a search for past posts on it. It has been discussed many times in these posts. I run one behind a 350 & it works fine. As long as a guy doesn't do burnouts or speed shifts I think it will last from now on out. It is the perfect way to deal with the low rear end gearing of these old trucks. A lot easier then putting in an automatic & much more fun to drive. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 |
