0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | So after getting my tires off. 1953 3100. (cutting them off because there was enough glue in there to seal up a whole factory of tires). I noticed I have 3 different sizes. I looked up the standard sizes in my resto packet, and looking at threads on here. But when I measure from the floor to the top, they are 17.7". If I measure where the tire would seat, then it is about 16". Is that the correct way of measuring wheels? to were only the tire seats? Its the same way across. If it is on the inside, I get 4", 4", 4.5", and 5". If I measure to the outside of the lip, it is about an inch larger. The 5" tire does not have the 6 hub cap prongs on it. The others do. I just want to make sure I'm measuring things correctly. If I'm correct, then I believe I just need one more 4.5 by 16. If I read things right, the 4.5" was an option for the rear to increase the load rating. let me know. Thanks. In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | David,
The 4" rim (4" "section width") is for a 6.00x16" tire (standard on 1/2 tons, front and back, through 1953); the 4.5" rim is for a 6.50x16"; and, the 5" that you describe is for a later/newer wheel/truck (no hub cap clips).
In 1954, the section width of standard wheels was 4.5" and was most commonly used with 6.50x16" tires (even though 6.0x16" was standard).
You are correct: get matching 4.5" section-width wheels for the clips and you will have the ability to use the same-sized bias-ply or radial-ply tires. If you will be buying used wheels, make sure the seller measures the inside section-width at the same place that you are measuring.
Tim
| | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | where could I buy new 16 by 4.5 wheels. Every where I look, all I see is 15". I don't mind buying used and probably will. I am just wandering. In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Place a Want Ad in the Swap Meet. Or, contact mothertruckeraz@aol.com via email. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do any of the new, after-market 16" 6-lug wheels come with the clips for 47-54 hub caps? Has anyone drilled the after-market wheels and added the clips? This would be valuable information for people looking for new, original-style wheels.
| | | | | Joined: Sep 2008 Posts: 226 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 226 | These rims are avail. in many places. Check you local classic junk yard. or Hemmings Motor News. There are a few midwest etc. listed. They will all have these rims.
Many for around 35.00 each plus shipping. I ordered some up for a customer a month or so ago.
It is a good idea to put a want ad in the proper spot as stated in a previous posting. and you can put on up on some of the chevy or gmc websites like Nechevygmc.org or Chevy talk for example.
keep us posted Poets Seat AutoAppraisals, Parts, ServicePast: General Motor's Master Technician Member: Northeast Chevy/GMC Truck ClubPhone Number: 413.774.5856 Collector of: 1951 Army Chevy Burb barn door,53 GMC COE,two 1934 Chevy Truck,1935 Chevy Army Truck.1950 Gmc Suburban clamshell these are just my chevy/gmc trucks.
| | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Can anybody pass along the front and rear, frame to inner fender distance on a Deco. Playing with wheel clearence too, and I have no metal on mine. Thanks in advance, Cavebull | | |
