2 members (Peggy M, UtahYork),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 502 | I searched and did not really find anything. On my half ton the doors will lock from the inside- the key will turn the outer lock mechanism, and slight turns the pin that goes to the handle, but it does not turn enough to unlock the door? Anyone else have this problem, I have tried lubrication(3/1 oil) and Check alignment and such.
And on my 3/4 ton. When you lock the driver's door it holds it open, not able to latch, flapping like a barn door in the wind kind of open. The passenger side will lock, but same problem as with the 1/2 ton not enough of a rotation to open the door(without breaking key in lock from turning/bending)
Thanks for the help. Kind of curious and I have put them back to what the book and the pictures in the assembly manual show as correct, maybe I am just overlooking something simple(Other than I am not the best door person) | | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | I don't know if you have a problem here, as my truck does the same thing. On my '50 you cannot unlock the passenger if the interior door handle has locked and my drivers won't close if locked from inside handle. If I am driving with someone, I have them lock the driver's from the inside before exiting and then I lock the passenger's side from outside without locking the inside handle. If I am alone, I either lock the driver's from inside and slide over, or reach in from the passenger side and lock the driver's, then the passenger's is locked with the key from the outside only. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't think the passenger door is made to be unlocked with the key if it is locked from the inside. It is risky to shut the door with the handle in lock position because I believe damage can result. Also, with some locks, they can lock unexpectedly when you close the door . The manual has some words on this. For this reason I do not lock my truck. | | | | | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | These locks aren't made to lock before you close them. You must lock the driver's side from the inside only, then lock the passenger side with the key. And here's something I learned a couple years ago on here- back in the day, people were to exit the car/truck on the curbside for safety- that's why there's only a passenger side lock. I don't know if it was a law, but I was told it was common practice. On my dad's 49 Packard the passenger side door is a bit more wore out than the driver side, makes sense because the car had always been in the city. As for the key not unlocking the door, I'd say something is worn out in the door latch. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
