| | | Forums66 Topics128,042 Posts1,055,519 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 35 | Does anyone know where I can buy the clam shell door locking hinges? The one that holds up the top glass part. Is there any other truck or something that will match that I can use. I really want to keep it original and use the correct ones.
Thank You,
Rey | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | Rey, I ended up using a Keyed "T" handle I bought from a Travel Trailer dealer.
With the square shaft it worked fine on my 46 Burb. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | I read somewhere that the Stationwagon supports are supposed to be close enuf to get by with. Also the cable retractors are supposed to work. Havent seen it actually done. | | | | | Joined: Jan 2002 Posts: 237 Shop Shark | | Shop Shark Joined: Jan 2002 Posts: 237 | I am using a Chevy trunk lid support, if it is not exact it can be cut to fit. [email protected] | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I think maybe first gen Blazers, jeep station wagon or first gen ford bronco is close. Of course Ebay will have them sooner or later and the "parts wanted" section here is great!!!!! Not sure what yours looks like. ther are plenty of guys and gals here who know where to get them, they will answer by and by.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
