3 members (Stewart2, 55shaker, 1 invisible), 145 guests, and 3 robots.
Topics128,165
Posts1,057,010
Members48,458
Anyone know of a source for a copper oil pressure line with fitting that will seal on the back side of the oil pressure guage on the 57 Chevy pickup? The threads on what I can find aren't deep enough. Thanks.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
3B Offline
Hy Jerry A, I'm not really sure if 57 still used the "threaded sleeve" setup that was used on older models, the p/n for the nut for 1/8" tube is 6100X2 which is a Weatherhead number, hope that helps.
Thanks. It's male and it's compression style.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
3B Offline
Hy Jerry A, if it's compression here are the Weatherhead p/ns for the compression sleeve and the nut for the line, you didn't tell us what size tubing so here are a few numbers
compression sleeve nut
1/8" 60X2 61X2
3/16" 60X3 61X3
1/4" 60X4 61X4
I'm sure you get the idea, hope that helps.
I'd bet it's 1/8" (very fine). I ordered a pair of 6100x2's from Aircraft Spruce today for $.44 each. They'll ship on Monday. Thanks again.
I checked the dimensions of the ones I ordered vs. what I took out and found that the thread went a bit deeper on the new part. That should solve the problem I had with the old one.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
https://www.stovebolt.com/ubbthread...;Main=66858&Number=482156#Post482156
Hey Jerry,
I was just looking for the same thing for my truck the other week. Check out that post. Surprisingly, I found everything at NAPA.
Dave
Dave
