3 members (FishinToms53, joe apple, Hotrod Lincoln), 81 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
Starting the rebuild on my '57 6 cylinder 235 cu. in. Which type of head gasket is better - copper or composite?
The very best nugget of wisdom anyone could ever offer you in dealing with your wife: You can be happy, OR, you can be right.
V
V Offline
I do not know which is "better' but I used the composite.
H Online: Content
The composite gasket is usually the "no-retorque" type, which saves a little time during engine assembly. The solid copper or steel gasket needs to be torqued again after the engine warms up. On the very high compression race engines I build, a solid gasket is an absolute necessity when the compression ratio gets above about 10:1, and the blower engines use a stainless steel O ring to seal compression, and a copper shim gasket to prevent water leaks. Unless you're going for extreme perfrmance, the composite gasket should work fine for street use.
Thanks guys. I'm taking the old girl back to bone stock condition with a full off frame restoration so think I'll go with the composite - compression is not high and I won't be running it hard - after its many tough years it will now lead a very spoiled life.
I can't speak for other brands, but the Fel-Pro composite gasket for the 235 does require retorquing.
Bill Burmeister
