3 members (Jay R, Hanks custodian, 1 invisible),
122
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I know I need a female Torx socket to adjust my headlights on my '98 Suburban daily driver. Anybody know what size socket that is?
Bruce | | | | | Joined: Sep 2006 Posts: 206 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 206 | Go to you'r local flaps,park right out front and see if they can find the right size.Or buy a 1/4 inch drive kit and you'll have sized for other project's!! | | | | | Joined: Jun 2007 Posts: 53 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 53 | try a 4 mm torqx it will do the job, MikeB | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Pick up a torx set, you will need it for more than headlights on your suburban. Everything from the distributor cap to trim is held on with Torx. My guess a T25 or T30
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Actually, it will the E Torx (External) Most likely, and E8 or E10. Best bet would be to get the kit, they're not too pricey, maybe $20 for a good set.
Bill Burmeister | | |
