7 members (cmayna, dt235sd, baldeagle, 1955 1 Series, NJC, 2 invisible), 93 guests, and 6 robots.
Topics128,016
Posts1,055,337
Members48,419
#488707 01/01/2009 4:01 PM
I know I need a female Torx socket to adjust my headlights on my '98 Suburban daily driver. Anybody know what size socket that is?
Bruce
My Trucks
Stuff I Collect
Go to you'r local flaps,park right out front and see if they can find the right size.Or buy a 1/4 inch drive kit and you'll have sized for other project's!!
grub #488730 01/01/2009 5:40 PM
try a 4 mm torqx it will do the job, MikeB
mike bourg #488743 01/01/2009 6:56 PM
Pick up a torx set, you will need it for more than headlights on your suburban. Everything from the distributor cap to trim is held on with Torx. My guess a T25 or T30
Actually, it will the E Torx (External) Most likely, and E8 or E10. Best bet would be to get the kit, they're not too pricey, maybe $20 for a good set.
Bill Burmeister
Moderated by  MNSmith
