5 members (baldeagle, Phak1, 66flea, 2 invisible),
49
9
Mod | | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48857 08/10/2005 6:29 PM | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | Will a distributor from a 250 fit in a 235??? | | |
#48858 08/10/2005 10:35 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There have been previous posts on it. They say it fits with slight modifications. I,d like someone to jump in & explain it. I,ve got one I can sell or use.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#48859 08/11/2005 1:47 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I just fixed one for my old doodlebug this past weekend and it works fine. I used a HEI from a 292. It is not a drop in swap. Do a search there is a very good thread on the subject. It took about a hour a little lathe work and fab a hold down clamp from the old dist. | | |
#48860 08/11/2005 10:17 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Here's an auction on e-bay I ran into today:
YOU ARE BIDDING ON AN H.E.I. DISTRIBUTOR NUMBER 1110715 FROM A '79 CHEVY 250 SIX INLINE SIX. IT IS IN VERY NICE, COMPLETE CONDITION. THE CENTRIFUGAL ADVANCE IS NOT WORN OUT OR SLOPPY, AND THE VACUUM ADVANCE WORKS FINE. IT'S EASY TO PUT ONE OF THESE IN A 1937-62 CHEVY OR 1939-59 GMC SIX; JUST GRIND OR MACHINE OFF THE LOCATING COLLAR ON THE ALUMINUM HOUSING AND USE A STOCK CLAMP-ON LOCKING DEVICE FROM A STOCK 216-235 DISTRIBUTOR. HAPPY BIDDING!
#48861 08/12/2005 1:12 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you search for a thread by Tony, alltruckedup, iirc, he gives instructions on how to do one on a grinder. Hence the name, Tony the Hacker.
Fred 52 3600 69 C-10
