2 members (NJC, baldeagle), 52 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#48857 08/10/2005 6:29 PM
I
I Offline
Will a distributor from a 250 fit in a 235???
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#48858 08/10/2005 10:35 PM
Riding in the Passing Lane
There have been previous posts on it. They say it fits with slight modifications. I,d like someone to jump in & explain it. I,ve got one I can sell or use. smile
1972 Chevy c10 Cheyenne Super
#48859 08/11/2005 1:47 AM
I just fixed one for my old doodlebug this past weekend and it works fine. I used a HEI from a 292. It is not a drop in swap. Do a search there is a very good thread on the subject. It took about a hour a little lathe work and fab a hold down clamp from the old dist.
#48860 08/11/2005 10:17 PM
Here's an auction on e-bay I ran into today:
YOU ARE BIDDING ON AN H.E.I. DISTRIBUTOR NUMBER 1110715 FROM A '79 CHEVY 250 SIX INLINE SIX. IT IS IN VERY NICE, COMPLETE CONDITION. THE CENTRIFUGAL ADVANCE IS NOT WORN OUT OR SLOPPY, AND THE VACUUM ADVANCE WORKS FINE. IT'S EASY TO PUT ONE OF THESE IN A 1937-62 CHEVY OR 1939-59 GMC SIX; JUST GRIND OR MACHINE OFF THE LOCATING COLLAR ON THE ALUMINUM HOUSING AND USE A STOCK CLAMP-ON LOCKING DEVICE FROM A STOCK 216-235 DISTRIBUTOR. HAPPY BIDDING!
#48861 08/12/2005 1:12 AM
If you search for a thread by Tony, alltruckedup, iirc, he gives instructions on how to do one on a grinder. Hence the name, Tony the Hacker. grin
Fred
52 3600
69 C-10
