1 members (baldeagle),
30
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | I am sure this has been done just about anyway you could think of ,but I am getting ready to pull my cab and will not have much help or a forklift,so if anyone could offer any ideas on what or what not to do ,I would help me out . Thank you Jim | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A good come-along or a chain fall has worked for me. Obviously you'll need something sturdy and tall enough to hang it from.
For an AD (47-54) truck remove the pedals, shifter, starter button, steering wheel and the seal around the column on the floor. Also disconnect all the wires and stuff. The truck will need to roll forward to clear the steering column on the way up. If it's to heavy removing the doors makes it lighter.
And for what not to do, don't drop it or hurt yourself..
Grigg | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'll second that don't drop it on yourself thought!
I've been removing the steering column too, making removal easier because you don't need to go as high, and don't need to have the truck or cab shift as the cab comes off.
Also I use my cherry picker with a 'cab lift' instead of a chain fall or come-along. The cab lift is a simple as a 4x4 laid on top the boom, with a couple of 2x6 pieces vertical on the back end that allow securing the 4x4 to the boom.
Another member built the one I used and its been in my shop since we used to move a cab that belongs to him. I seem to use it frequently and have removed both AD and S-10 cabs with it. Someday he'll ask for it back, and I'll need to build my own.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Here is a link to Mongo's cab lifter I think I might build one of these, looks like it would work great.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Nov 2008 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 64 | Thanks for the great idea's,I really think Mongos cab lifter will work just fine.I will get started ASAP. Thanks again Jim | | |
