| | | Forums66 Topics128,186 Posts1,057,309 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 34 | i have a question i got one of my 1955 second series truck fenders the fender is in good shape except for when i removed the headlight ring up in top its rusted out not the eye brow they call it but the metal that is in a half circle over the headlight does eith one of the new replacement panels you by like a new eye brow or even the new front facepanle include this metal to be repaired ??? or would it maybe just be a good idea to fabricate me a reapair panel out of sheet metal??? | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | It would be easiest to find a good used fender. The repros don't fit terribly well. The second easiest would be to find a dented rear fender that has good metal where you need it and use it as a patch panel.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Check LMC's catalog or website, they may have a patch panel for what you need. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the "front section" panel includes that area, the "eyebrow" or top panel does NOT include it, and it's not available alone .... the TF series patches are pretty good, but if all you need is that hidden area you'll have less work to fab it yourself .... and make sure you get all the nooks and crannies in behind cleaned up or you'll be doin it again before long
Bill | | |
