| | | Forums66 Topics128,129 Posts1,056,697 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | Anyone know of a source for a copper oil pressure line with fitting that will seal on the back side of the oil pressure guage on the 57 Chevy pickup? The threads on what I can find aren't deep enough. Thanks. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jerry A, I'm not really sure if 57 still used the "threaded sleeve" setup that was used on older models, the p/n for the nut for 1/8" tube is 6100X2 which is a Weatherhead number, hope that helps. | | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | Thanks. It's male and it's compression style. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Jerry A, if it's compression here are the Weatherhead p/ns for the compression sleeve and the nut for the line, you didn't tell us what size tubing so here are a few numbers compression sleeve nut 1/8" 60X2 61X2 3/16" 60X3 61X3 1/4" 60X4 61X4 I'm sure you get the idea, hope that helps. | | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | I'd bet it's 1/8" (very fine). I ordered a pair of 6100x2's from Aircraft Spruce today for $.44 each. They'll ship on Monday. Thanks again.
I checked the dimensions of the ones I ordered vs. what I took out and found that the thread went a bit deeper on the new part. That should solve the problem I had with the old one. | | |
