7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible), 82 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
i got a question i got a 1957 chevy truck 3100 and im wanting to install a 1955 56 grille is the top panel and the lower grille panel the same to acompany the 55 56 grille i mean to bolt up the same as the 57 grille did at the top and bottom to these panels i know i got to fill in the two holes that are in the face of my 57 fenders where the 57 grille outer ring bolted .
fits right in other than those side holes
ok thansk alot it looked like it all would work just wanted to make sure the only thing i see i got to do id wled up or fill up the front mounting holes where the 57 grille bolted in two spots .
