9 members (Gdads51, 55shaker, fonz8261, jay d, TUTS 59, Otto Skorzeny, Jims46, Hotrod Lincoln, 1 invisible),
76
Mod | | | Forums66 Topics128,288 Posts1,058,546 Members48,491 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#48766 08/07/2005 12:11 PM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | I was searching for valves on the web for my new  484 head (that if found to my great surprice on a 1959 235 block - 100$ together - that turned out to be a 261  ) I found Sealed Power valves for $5 each and Stellite Valves with chromed shafts for $14 each. Is it worth the extra cash? Thanks, Frank | | |
#48767 08/07/2005 3:36 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The stellite valves run cooler. They are for heavy duty service. I wouldn,t use them unless you are putting it in a large truck & are going to do some heavy hauling. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#48768 08/08/2005 12:34 AM | Joined: Jan 2002 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2002 Posts: 59 | Hello, The stellite valves together with hardened exhaust seats is is great if you want to run your truck on todays unleaded gas, I would use em if it were my truck... | | |
#48769 08/08/2005 12:42 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | That means for a daily driver (no heavy duty service/towing at all) without hardened seats it makes no sense to spend 3 time as much as for the standart valves?
It may see some driving on the german Autobahn but I have an overdrive so I keep under 2500 RPM.
Thanks, Frank | | |
#48770 08/08/2005 1:36 AM | Joined: Aug 2004 Posts: 399 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 399 | I´m glad you like our sites. Some friends are in the process to build a "GIs in Germany" Museum here in Augsburg.May be of intrest if you come over.
Many greetings from sunny southern Germany,
Frank | | |
