Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (woodrow2002, cmayna, dt235sd, Thom75, 1 invisible), 111 guests, and 3 robots.
Topics128,290
Posts1,058,557
Members48,491
#48766 08/07/2005 12:11 PM
I was searching for valves on the web for my new grin 484 head (that if found to my great surprice on a 1959 235 block - 100$ together - that turned out to be a 261 grin )
I found Sealed Power valves for $5 each and Stellite Valves with chromed shafts for $14 each.
Is it worth the extra cash?
Thanks, Frank
Riding in the Passing Lane
The stellite valves run cooler. They are for heavy duty service. I wouldn,t use them unless you are putting it in a large truck & are going to do some heavy hauling.
1972 Chevy c10 Cheyenne Super
#48768 08/08/2005 12:34 AM
Hello,
The stellite valves together with hardened exhaust seats is is great if you want to run your truck on todays unleaded gas, I would use em if it were my truck...
#48769 08/08/2005 12:42 AM
That means for a daily driver (no heavy duty service/towing at all) without hardened seats it makes no sense to spend 3 time as much as for the standart valves?
It may see some driving on the german Autobahn but I have an overdrive so I keep under 2500 RPM.
Thanks, Frank
I´m glad you like our sites.
Some friends are in the process to build a "GIs in Germany" Museum here in Augsburg.May be of intrest if you come over.
Many greetings from sunny southern Germany,
Frank
