3 members (Rexville48, dwreills, Gdads51), 152 guests, and 3 robots.
Topics128,036
Posts1,055,460
Members48,422
#48735 08/07/2005 4:49 AM
Apprentice
Apprentice
Hello,
The clutch in my truck (54 Chevy 6400) does not return after depression. It disengages the transmission, but just stays at the floor. You can manually pick the pedal up and it re-engages, but that's not right. Is this a spring issue or a worn out clutch/pressure plate?
Thank you,
J.K.
#48736 08/07/2005 5:16 AM
might be pressure plate, but more likely the return spring on the linkage - crawl under and take a look!
#48737 08/07/2005 5:21 AM
Apprentice
Apprentice
Sounds good. I'll check it out in a little more depth.
Thank you,
J.K.
#48738 08/07/2005 12:50 PM
V
V Offline
the pressure plate should engage the clutch by its self with no help from the return spring.
#48739 08/07/2005 12:57 PM
While checking the return spring lube the hinge point for the clutch petal. These can get very stiff with years of neglect.
#48740 08/07/2005 3:31 PM
Riding in the Passing Lane
Put more freeplay in the linkage. The diaphram in the clutch is probably going overcenter.
1972 Chevy c10 Cheyenne Super
#48741 08/08/2005 5:52 PM
Apprentice
Apprentice
Thank you guys for all the input. I'll check it out next weekend.
