2 members (Shade Baby, 1 invisible), 110 guests, and 1 robot.
Topics128,154
Posts1,056,831
Members48,456
Hi, I'm a new guy wondering what the procedure is to replacing inner and outer cab corners on my 59 gmc short box?I have the new parts. Can it be done with cab on truck?
If the bed is off, you should be able to do that. This is not from experience, just the fact I have pulled my cab and bed off the frame and have ordered new cab corners to replace them. So I have simply seen what things look like when they are apart.
I pulled the cab more so to get at the frame than the cab corners, but in the end I think I will be glad I did as it will be easier to do the toe boards, brake master, and trans mount, etc.
http://www.brotherstrucks.com/techarticles.asp Brothers has a tech article on doing the corners, but they have the cab off the frame. But if you look at the pics you can see the frame mounts considerably inboard of the corners and with the bed off I think it is doable.
R-Bo
1966 GMC 305V6 in the family
You've probably heard this a million times (I know I did and still ignored it) keep the truck intact (doors, hood, fenders) as much as possible (and at ride height) when doing patch panels. Ignore it and you'll be doing the panels twice like I did. (DOH!)
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
You Tube
Thanks for now and Happy New Year
Garth
Garth
Thanks for now and Happy New Year!
Garth
