4 members (Wayne67vert, Gray_Ghost, BC59, 1 invisible), 155 guests, and 2 robots.
Topics128,164
Posts1,056,965
Members48,458
Installing disk brakes from MP brakes on a solid axle Chevy 1/2. The original ears on the spindle are off set with big and small spacers. The big spacers were at the top and the small at the bottom. The spacers with the kit do not align the new caliper bracket with the spindle? The directions are horrible and incomplete. Do I use any of the orig spacers? Any and all suggestions would be appreciated.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
Jim & Caroline
Jim & Caroline
Nice set up! So what disk brake rotors did you end up using? Are they on the stock hubs? Any other mods done? What is the intended master cylinder?
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
thanks 302,
yes many mods done to my wife's rig, something like 50+ to this truck. see photobucket......
the brakes were 'on sale' at Brothers http://www.brotherstrucks.com/catalog-request.asp many yrs ago. i bought the power master, taper bearings & disc kit at the same time. these were all developed by an old friend and sacto mechanic Buffalo Steve who now lives in wash state. he never did get a patend
tooooooooooo baddddddddddddd
most if not all of these kits were/are made by 2-3 companies one copied another copied another.
see the above for the adj link set up and don't forget to weld that BIG 3/4'' nut to the tie rod END . yes these use stock hubs. not sure about the master cheac W/ CCP or was that CPP. http://www.classicperform.com/
http://www.classicperform.com/NewProducts/DiscBrakeKits/FrontBrakePackage.htm
http://www.classicperform.com/tech_articles/Pedal_Power/Pedal_Power.htm
most of these trucks use::
BRAKE SET UP
1951 DELUX 5 WINDOW CHEVROLET PICK UP
MY VEHICLE IS EQUIPED W/ :
FRONT EQUIPMENT:
➢ 1971 ~ 86 CHEVROLET K – 5 / 10 BLAZER 4 WD ROTORS.
➢ 1971 ~ 87 CHEVROLET C – 10 TRUCK 2 WD (HEAVY) CALIPERS.
Jim & Caroline
It done. Overall the "MP Brakes" kit went on ok so long as you don't follow the directions too closely. Given what we pay for these kits the directions should be better. I taked with the company and they will be making changes. The followning was different"
Direction item 3. You can not use the original bolt & spacer to attach the steering arm to the bottom forward spindle ear. If you do the rotor will scrape. Go out and buy new shorter grade 8 bolts, castelated nut and lock washer. Drill the holes last to put the cotter key. Most importantly and my biggest time waster was trying to fit up the caliper mounting bracket on the back of the spindle as the directions said. Forget that the bracket can only goes on from the front of the spindle with the spacers on the three bolts. I put the bolt heads on the inside with locknuts facing out. So the stack up is like this: on the inside will be steering arm, then spindel ears, spacer, caliper bracket.
Direction item 8. Directions say outer bearing A-12 in the kit is actually outer bearing PTA-2. It is not necessary to exchange the outer bearing races as the rotor will come with the outer race already installed. Just use that one and put in the PTA-2 roller bearing followed by the 3/4 inch by 1/4" brass spacer. Finally install the original keyed washer and retaining nut and new cotterkey not supplied.
Important: You do have to knock out the inside caliper rear bearing races and put in the ones installed with the kit to match the new inside bearings. The only advice I can give here is make sure that the races are completely seated. If not the calipers will not go on smoothly. Guess how I discovered that?
Make sure you install a new disk/drum master cyl with 2 lb residual valve on the front and 10 lb on the rear drum brakes with a porportion valve.
